Selection Panel - Number of items selected?
Last post 08-20-2009 3:01 AM by martinkopplow. 4 replies.
Page 1 of 1 (5 items)
  • 07-01-2009 1:34 PM
    When using the Selection Panel to select "equal" objects, is there any feedback given as to the number of objects selected other than having to count the number of items in the "Related" tree?
     Thanks
  • 07-02-2009 12:51 PM In reply to
    Re: Selection Panel - Number of items selected?
    Hi Shinmn,
     In what cases would you want to know the number of geometric entities that lie on the object?
     Roman
  • 07-03-2009 11:29 AM In reply to
    Roman,
    The case in which I faced was that of a number of counter bored holes on a plate.   To make sure all holes were of the same dimension I use the Selection Panel to select all holes of equal radius.    Since I knew how many holes total were on the plate, I naturally wanted to make sure that the number of selected 'equal' holes was the same.  The only way that I see to do this is to count the number of child nodes in the tree and then add one for the parent node.   For a small number of objects, this process isn't too bad, but wouldn't scale at larger numbers.   I think that the actual number should be reported somewhere.   If you have the measure tool going, a couple of pieces of information pop up, but not the actual count.  Perhaps I am just missing it (Style 2009 SP1)?
    As it turned out, one of the holes on my plate was not the same as the others.  I was probably experimenting with different screw sizes and forgot to re-adjust the diameter after I was done.  If there is a better or different workflow for handling this type of situation, I am all ears.
    Thanks.
  • 08-19-2009 4:55 PM In reply to
    sorry for letting this slip through the cracks.  i've filed this enhancement and will keep you updated on the status.  i like it and think it will help give the user more feedback.
    Roman
  • 08-20-2009 3:01 AM In reply to
    Yepp, I'd also appreciate this kind of feedback.
